PROBLEM! passenger floor board is soaked
evomind
as the title suggests...
my guess is condenser coil from the A/C??
06 coupe, 500 miles on it....
suggestions?
(yes, i know its under warranty)
thanks
adamlotus
los angeles
is it water or coolant?if its water the drain for the ac could be restricted and causing it to leak inside.
Kenneth Krieger
Metro Phoenix
Look for the "drain" from the A/C condenser to be plugged, pinched, or not even hooked up properly......it has to be the drain......
Fast Viper
SF Bay Area, CA
I Had this problem. If you get a flashlight look under the dash and you will see a black hose that should be outside the car but is inside.It's water pretty much from the AC, it's a 5 second Fix, very simple. The AC drain hose should be visible from the outside, on the inside of the wheel cover, turn the wheel if you cant see it
E
evomind
thanks everyone....
deam, if i see the hose under the dash, how will i route it outside the car?
thanks
SylvanSRT
Sylvan Lake, MI, USA
i may be thte sealent that seal the footbox (underhood) on my car they found pin hole size openings in the area where the two pieces of sheet metal come together and when the car was washed or in rain the water would come int o the foot box in the car(pass and driver side). they had to remove the front quarter/fender panel and reseal the two foot boxes under the hood.
BarryLB
