Questions about Spark Plugs
Jim Wilson
Chandler, AZ, USA
I'm running a DLM SC setup, about 12 psi, ported heads, cam headers, etc.... Doug recommended a NGK BKR7E-11 plug (2 steps colder than stock) gapped at 0.034-0.035 and they perform great. One question is why does the NGK website recommends 0.044 gap.
http://www.ngksparkplugs.com/docs/tech/partnumberkey.pdf
Are there better plugs out there now?
I do like to stick with what works, but like to keep open minded to new technology. Does anyone know where I can pick up a set of plugs that will work well with this application? Maybe I should stick with the NGK BKR7E-11 plugs?
If you know where can pick up a set, please let me know. They are hard to find.
Thanks,
Jim
99 R/T 10
Enterprise, AL USA
Yep, the best plug out there (IMHO), Champ. RC10ECC, if you can find them. Two step colder plug, great driveability.
99 R/T 10
Enterprise, AL USA
Are these NGKs # 4554? If so, here are a couple of pictures. You can see the differences.
miamispd
What is the stock heat range?
What is recommended for a TT application?
Thanks.
xeng yang
