Quick subwoofer replacement 2000 RT/10
DaJerseyViper
Nice!!! Can you get the stock Grill on with it? If so Ill take the other one off your hands.
90ZR1
Old Bridge, NJ
I believe you can. I didn't even try. You are a wealth of info to me so I'll just give you the other speaker!
GTSHolgi
Germany - Rheinland
... and now have BASS again! YAY
Do you think you have "real" bass? I have played around with the stock location between the seats and different speakers. None of them was able to deliver what I would call real bass. Main reason for this as I believe is, that there is no enclosed volume for the driver in the OEM Location. I ended up building a footwell sub using an 8" driver (a trunk solution will not work either in the roadster). This is what I would recommend to anyone who wants to have some "real" bass ;-)
Steveeto
I'm also very interested in whether or not you can fit the original speaker grill back on?
Do you have a model number for the new speaker?
ViperJohn
Maryland
I replaced mine with a JL Subwoofer quite a few years ago. I was able to get the stock grill back on.
90ZR1
Old Bridge, NJ
Idk if I'd call it "real" bass but it certainly sounds better than the blown, crumbly speaker that was in before.
Yes, you can get the original grill over new speaker
BarryLB
