Racing harness for stock Generation 1 Viper
gobigblue42071
I am looking for a 5 or 6 point racing harness yellow in color that will mount in a 1994 Viper RT/10. The car is stock and doesn't have a roll bar to mount it to. Any advice or suggestions would be much appreciated!
DrumrBoy
GA
I know this likely isn't helpful, but I've not seen a proper racing harness affixed to anything other than a rollcage element. It might be possible but you're going to have to find secure mounting points somewhere, otherwise the harness will be unsafe. No worries if its just for show.
I was pretty sure the factory has hard points built into the car already for harness similar to the later generations. I know my mom's 94 has a crotch strap hole already in the floor directly in front of the seat, but I think to get to the shoulder ones you actually had to remove the plastic panel behind the seats and cut it up. The later gens have the removable panels to access the holes, but I don't think the earlier cars had any provisions like that.
FrankBarba
Yes it can be done. You will have to remove items that you most likely do not want to remove & hack up.
It will change the look of your interior.
jp
Umea, Sweden.
There is two welded bolt threads behind your neck, but you have to remove the panel and replace it with a aftermarket piece with holes for the shoulder straps.
Below the seat you have one anchor point for the fifth point of the seat belt.
steve e
Didn't the ACR come with 460hp vs GTS 450?
Yes, same engine, in the ACR they replaced the accordion type hose that went from the air box to the throttle body,with a smooth hose and a K&N filter, presto, 10 more hp.:)
Drock187
