BigBadViper
I have bounced mine off the rev limiter several times. It has always been on upshift. I have never had a problem with mine - Yet.
Make sure you didn't switch #1 and#2 sparkplug wireseverything back together..
codes p0301 and p0300 now..
-sigh-
I was on the storm chaser forum and noticed the helmet cam video you posted over there . Do you think some flying debris could have pierced the block? That footage looked pretty rough.
I don't know what the "real" rev limit is on these cars. But if your tune put it on the edge and you passed it then it is possible you did some real damage. Personally I would follow the above advice.
You're killing me man!
Jim
I am hacked that Twister didn't let me know if he could see my experimental punctuation picture that took an exorbitant amount of time to create. Until he does, more shenanigans.Do you have any shenanigans to share?I am hacked that Twister didn't let me know if he could see my experimental punctuation picture that took an exorbitant amount of time to create. Until he does, more shenanigans.
I'm waiting the results of the much suggested compression/leak down tests etc....until then, I am shenanigansless, I am without shenanigan, I am shenanigan-free...
Jim
the face palm was very inique no doubt..That video of the tornado is one of my favorite..Amazeing force
I cleared the codes and drove 2 miles..The check engine light popped back up but it was only the p0301 (misfire at sparkplug 1) the p3000 isnt coming back up (multiple misfires) and the p0320 (crank shaft sensor) hasnt come back on at all...
Dark now and Im tired....will mess with spark plug and boot number 1 tomorrow and see were that leads
twister has an SCT tune, maybe it doesn't have a limiter ?
good info on the bent pushrod. hope thats all it is...
If you are going to attempt to do a compression test make sure you disable the coils so it won't start during the test. I'm not sure if that was mentioned.
How do you disable the coils?
OK OK OK....
I messed with the p301 misfire at cylinder 1 and readjusted the boot to be a little more snug on the plug...car ran better than ever for about 10 minutes. Than the p0302 (misfire in cylinder 2 came on) Im gonna check that plug shortly but its starting to worry me a lil...
I know how to pull the covers but honestly I wouldnt even know what the hell Im looking for..
Thinking I will just adjust number 2 boot and plug for a good connection and see what she does. Then pull the coveres
bluresrt I have no idea how to do a compression test..hell that was the first time I ever changed my own spark plugs
