Spark Plug Wires
Saratoga,CA
Depends on what you consider better. Looks, performance, life, etc. MSD makes a nice set that works in high temp applications, but the stock wires will provide the best engine performance. The ORECA engines use stock plug wires, fyi.
JonB
Legacy\Supporting Vendor
Columbia River Gorge
Bang-4-buck, you cannot beat OEM wires ($60/set!)
So cheap you could keep a spare set in the garage!
If you have headers: PartsRack has protective boot/wire sleeves we call "Snake-Sox" that slide/slither over the boots. Avail in various lengths for OE or aftermarket aplication.
JonB
JonB
Believe it or not, 1992,'93, and ~94.2 wires can deteriorate if they have ZERO miles on them ! The BOOTS were inferior.
Generally, HEAT, oil/road film, install abuse, headers, heat-shield abrasion, etc, can all shorten normal wire life.
Since OEM are so inexpensive, sooner is better...ie every 25K-30k miles, or 3 years, after 1994. SOoner if older car.
zeeshan_k24
