Throttle Cable Play
10 BANGER
I did a search and could not find an answer.
I have about a 5/8" (up & down) of play on my throttle cable.
I've adjusted it as much as it will allow me and I think it has worned parts that might need replacement. How can I make additional adjustments besides the one on the intake. Iddle screw is the only other adjustment I see but my iddle is good.
Is this normal?
Thanks.
06' Vert
Nader
New York
Mine has about the same. I have wondered about why there is that much play in the cable.
10 BANGER
It is normal leave it alone and pull the intake if you want to insure you are getting WOT.
Could you be more specific. I just got done installing the intake.
Not sure what you mean by pulling it.
Nader
New York
Mark how do you tell? is there a stop or should it perfectly horizontal to the throttle body?
Ideal983
