azvipermike
i am looking to add some power. i was thinking a cam,headers and tune. What other changes when doing the cam on an 01 do i need to do? springs,lifters,pushrods,rockers?
always listen to camfab on this stuff and greg good.
+1 Listen to Plum, its great advise!Evo, I don't think anyone was specifically asking about total price. I just threw it out there, based on cost per HP. It also depends on how you do it. Striker head (if you can find any) or having Greg port your stock castings. Don't forget options like which rockers you get, Valve type and size etc. etc. If your car has headers and a good aftermarket exhaust, that's 4K you don't have to spend.
Depending on what roller rockers you use and who does the cam and head work you can look upwards of $5-6K. As Camfab mentioned, Stryker Heads are considerably moe expensive than the typical stage 3 ported heads. Hard to be too specific with pricing as there are many variables to consider when doing engine work.
would you say 7k cover probably cover parts and labor or no?
as there are no stryker heads anymore id probably just go with stage 3 heads and an upgraded but streetable cam
Perhaps someone can chime in that has the stryker package and validate this?what if you already have headers, intake, etc and are looking to get more top end out of the engine and want to do heads and cam?
what does it cost to do it right parts and labor from a shop?
hey camfab, actually i did ask, see post 5, i think. lol
just trying to get a ballpark figure for heads and cam done right, that means whatever parts it takes to achieve that, quality rockers, valves, whatever.
thanks
Doh, I meant post 8.See post 5.
