WET FLOORBOARD??????
SCOTTB
ALTOONA, PA
My passenger side floorboard is always wet after a wash. Is it common for these to leak seems like its coming from under glove box
kennyhemi
Miami Fl
I had the same problem with my 06 copperhead coupe and had to replace the weatherstrip that raps around the door opening, Mine was on the driver side. (warranty):2tu:
Omaha NE.
Have seen a couple of these also ended up being a kinked weatherstrip that was allowing the water to get through and follow the bracing to the middle of the dash on either side.
SylvanSRT
Sylvan Lake, MI, USA
i had similar problem and the actual frame from inside engine compartment was leaking where the parts of the chassis parts(more specifically the top of the foot boxes) are joined and the dealer found some pin holes that would leak from rain or washing
Kenneth Krieger
Metro Phoenix
It could also be the drain for the condensation of your A/C unit......make sure that the drain is not clogged or that the drain line is kinked!!
potterb4
