What are the two plugs at the very bottom of the diff is for?
YLW DRM2
Can I use one of those two "plugs" to drain diff oil? The picture is kind of dark, but you can still see two plugs athe upper side of the picture, kind of in the shadow:
Y
YLW DRM2
Drains yes, but the 2 are for installing a cooler.
Thank you! So I can use one of these plugs to drain my diff under the simple gravity force instead of using sucking pumps from the "drain" plug.
PaViper
Yes, I used it to drain mine and they work just fine.
Y
YLW DRM2
you could really use a service manual.............
I have it, at first I lost it and yesterday I found it, however, when I looked it up in the service manual they did not specify what these plugs are for :dunno:.
shibbydude
