EllowViper
Couple of observations.
1). The vacuum/boost line from the manifold to the VEC must not be obstructed/kinked/etc. Need to make sure the VEC sees the actual MAP reading. Sean really hits this point hard when discussion tubing sizing and "T" ing into the line.
2). Make sure the VEC is using the internal MAP, not the stock MAP.
3) Calibration of your W/B. Agree with 1Tony1 that the W/B readings may not be accurate. I use my readings right off the gauge and compare with the VEC log to make sure its the same. I have messed this up before and had the VEC data log reading differently that the Innovate gauge. For whatever reason, I use the 7.35 AFR at 0v and 22.4 AFR at 5v per the Innovate default settings. Sean told me to use 8.0 AFR at 0v and 18 AFR at 5v for VEC logging but when I do that, the gauge reading and the logs are off. Trust but verify your WB readings!!
4) My 5 lb ROE boosts right to 5 PSI and climbs up to 8+ at redline. My boost gauge and data logs are spot on. I have "real time" data in my face as I drive and do not rely on pulling logs to see what is happening "after the fact." My AFR at idle is 14.5-15.5. WOT I'm at 12.5. My set-up has always been detonation tolerant even using the stock plugs. I had been using the 2-step colder NGK that Sean provided but it ran like crap; nonetheless I have just incorporated W/M just because I could. I am not running much (if any) timing retard and in some areas advancing the timing above stock. Something was askew in your initial set-up since your engine was so suseptable to detonation across the spectrum.
I had detonation at first too with the stock PCV system. When I took the filter apart it was dripping with oil. I was sucking oil into the intake and detonating. You must not let the PCV vent vapors get sucked back into the intake!
