SoCal Rebell
The frame rails that I can see are too far toward the middle for my low profile Gen2 jack to reach. It is an ACR if there's any difference, but I don't "see" a jack point in front.
it is really funny that they did not note them in manual at least for my '03
I DO NOT know about the 2008 Viper...but,
03-06 have small, short triangular tabs that project downard at front and rear of the sidesills...and, to SAFELY use the front ones, remove the small plastic baffle at the bottom/rear of the fenderwell splash guards (take out the 3 push pins).
You can usually lift the entire side of the Viper by jacking from the rear lift point and get a jack stand under the frame rails front and rear, this is the nice thing about having a stiff frame!
Not being a smart ass, I need to know because I need to do this to get at my simms.If you are using the jacking triangle then you can put the stands on the frame rails.
