Won't start.
LADD
AZ
Can someone please help.I just went to start my 95 and I have computer and dash lights,radio works,BUT the motor won't crank.
I checked my battery it reads 12.79.Could it be the clutch switch?
I'd sure thank you for some help.
Boxer12
Colorado High Country
Ok, start with simple solutions. You do have the clutch fully depressed, right? Nothing (like floor mat) obstructing it? Do you get a 'click' when you turn the ignition switch?
L
LADD
AZ
BOXER 12,
Thanks,Yes to both, clutch all the way to floor ,no floor mats,i'm pretty sure i here the click.does the clutch switch move up and down on the clutch shaft?,also i did find a c lamp on the floor? can't see where that goes,don't even know if that has anything to do with problem,but it just showed up.the dash all lights up just no cranking,THANKS
L
LADD
AZ
STEVE THANKS,IT IS THE CLUTCH SWITCH,THATS BAD.I bypassed it and it fired right up.So now to figure out the switch fix.THANKS AGAIN
V
Venomiss
Guest
Now that you helped him get his Viper running can you get him to join the VCA?:)
Signed,
The rah rah sis boom bah club.:Drrsbc
zeeshan_k24
