I purchased a 1996 Viper GTS a few weeks back that has Eibach springs and Koni shocks. The wheels are 19" HRE Performance Wheels all the way around (13" wide in back). I understand that this Viper had 17" rims stock.
The tires are as follows:
front: Michelin Pilot SPORT 285/30ZR19 (94Y) Radial X
rear: Michelin Pilot SPORT 345/30ZR19 (105Y) Radial X
I am having a problem whereby the back tires are scraping against the inside edge of the "fender" (the edge of the blue part of the body panel where it curls under the wheel well). This is shaving bits of rubber off the sidewall of the tire (starting at the top of the lettering going up to where the tread pattern starts).
I chalked the sidewalls and went out driving. I could not recreate the problem after standard city driving. The chalk gets smeared vertically when going over speedbumps, so I was hoping that was the only cause (cure: avoid speed bumps). However, I then accelerated quickly down a straight-away and noticed I took the chalk off in a nice ring pattern all the way around the sidewall, indicating that when I accelerate hard enough to push the back end of the car down, I get scraping.
I'm not sure how big of a problem this is, but I'm hoping to run at Willow Springs in a couple of weeks so I'm trying to come up with a way to fix it, if need be.
I spoke with Marc at HRE and he can mill up to 4mm off the back of the wheel, but this is costly, and he wants me to check the swing of the wheel assembly first which requires special tools, etc.
Another choice might be to cut away a little bit of the edge of the body panel where it curls under the wheel well (pretty well hidden).
Does anyone else have this setup on this car who IS NOT having problems? Please distinguish between Pilot Sport, Pilot Sport PS2, and Pilot Sport Cup in your response. Also, the "P" (or lack thereof) in front of the tires size seems to be relevant.
Has anyone else has had this problem and, if so, what did you do to rectify it?
Has anyone limited suspension travel to fix? How?
Has anyone cut away a little bit of the "fender"? How did you do it, and were you successful? Does anyone know what the body is made out of and what the best cutting tool might be? Maybe there is another way to solve this.
PM me if you want some higher res pictures. Forum seems to limit the size (thus, quality) of pictures I can upload.
Thank you in advance for any suggestions!
Ken
Ken
