Air conditioning revisited
coolbawn viper
My 1995 RT/10 recently had a failure in the air con. Turned out the the system was losing gas.I located the problem eventually,the return pipe (larger pipe) from the compressor had rubbed against the engine on the right hand side where the take off for the oil cooler protrudes and worn a hole.This car has only done 5000 miles and nothing in the engine bay has been touched.This obviously was an assembly problem when it was built. Has anyone else had this problem and was it a recallable fault. Where can I get this pipe and a drier for the system
Jeff Torrey
Plaistow, NH USA
Re: Air conditoning revisited
You can get parts @ any Dodge Dealer. Call Chuck Tator at Tator's Dodge 914-763-3136. He will be happy to answer any questions and discount the parts.
Big Medicine
Cypress, TX
Ditto
call Tator
He ships EXACTLY what you need no questions asked.
Wizard if you're reading this, my check's in tha mail.
You should write a book on customer service.
Larrybf
