Lanceromance
- Joined
- Aug 24, 2008
- Posts
- 39
- Reaction score
- 0
So I just checked and my car jack cant get underneath. Any suggestions?
...or any low profile jack. ....Harbor Freight or ?
On my 97 RT10 I found you have to raise the car evenly, not just the front jacked up because the drain plug is in the center of the oil sump. So for all the old oil to drain out the car needs to be level.
Same here, drive on and walk under.+1, i do my oil changes on a lift.
The harbor frieght $59.99 jack is awesome! Just used it last night.
Look here complete with helpful pictures.
http://forums.viperclub.org/srt10-srt10-coupe-discussions/617529-changed-oil.html
mine (Harbor Freight jack) works fine at the jack points, though since last use i have cut 4 small pieces of 2x12 (45 degree miter on leading edge) to drive up on
with the coupon, the jack is a good deal
With the Harbor Frieght one I didn't have to drive onto anything, just used the jack at the jack points.
