Back-Up Light Problem
Vip23er
Olathe, KS
I just noticed on my 2003 that the back-up lights are not working. I checked the owners manual and could not find the fuse that dealt with the back-up lights. Does anyone have any ideas what I can check?
V
Vip23er
Olathe, KS
No, I have not checked the bulbs. Since both were out, I assumed it was something else. I can give it a shot.
XLR8SN
Does the 2003 have the same transmission and selenoid as the 2000 T56 transmission? If so, my issue was the selenoid on the transmission itself.
Both lights went out at the same time.
Viper Wizard
South Salem, NY USA
Common problem, back-up light switch! If you unplug the B/U SW [right side of trans], turn your key on [don't start her] and then jump the connector with a paper clip, the B/U lights should come on? If they do, you need the switch. It is the same switch for all GEN's and I have plenty in stock. If you need one, I'll be back to work on 9/2 after the VOI. :cool:
BarryLB
