Brake Booster Problem?
Xhlr8n
got an 04,
the brake pedal is hard with little to no stopping power, checked for vac leak and couldnt find any, there is a hiss sound in footwell when brake pedal is pressed, is it the brake booster? anyone else have a simular problem?
tia
tom
Racer Robbie
Guilford, CT-USA
Sounds like it could be. Check the tubing between the engine and the booster and make sure there is not a loose connection. Also check the one way check valve at the booster, it should only flow one way toward the engine. If everything is fine I would believe you have blown the diaphragm in the booster.
zeeshan_k24
