cluch problem?
jeffdai
mechanicsville, md
When i bent a shifter fork on my 1994, they changed my clutch also. I noticed now when i rev the engine up past 4500 rpm with the clutch in all the way in first gear the car will start going forward at 4500 rpm. I also noticed that i cant shift gears much about 4500 rpm as soon as the rpm drops below that i can shift right in. Any ideas?
Viper Wizard
South Salem, NY USA
It could be a few things? Is the clutch system bled properly [all the air out], slave cylinder working correctly [the travel], did they use a LUK clutch [oem], did they replace the flywheel or did they turn it [hope not?], all bolts tight?
J
jeffdai
mechanicsville, md
wow lots to check, ill try bleeding it and also ask them those questions, doesnt feel like the clutch used to, a lot easier to press the pedal now, ill find out what kind they put in it. Really appreciate the ideas of things to check, ill let you guys know what i find out
zeeshan_k24
