wastntim
With all the talk about the expense of NA power, I am wondering what the cost of replacing with cast with forged? Typical install cost? I know the Roe is about $7k plus install and tune.
Talked to two tuners today, and both recommended going this way over the heads/cam 550-575 rwhp way. Going to talk to two others tomorrow hopefully.
What ever you do DO NOT USE Diamond pistons! They are JUNK and the company *****!!
I use here CP coated pistons and to do just a piston change, it would cost you $5500-$6500.
problem is you end doing a lot of "might as wells" and that brings the cost up a bit.......
might as wells = main caps,rods, etc....
...and cam, rockers, lifters, etc. I had a nice discussion about this with Greg Good. He says thanks for the referral Phil. I finally followed up with him.
Just my $.02 and I am sure I am going to get beat up on this but... I have a dyno sheet for my car which is basically stock at 430 at the rear wheel. It sure seems like a lot of money being quoted to get an additional 50 - 100HP. Now I realize it is all relative but it would seem that for $5K + you would/should get more than 50 HP. Perhaps the car is so far along that it takes that much? I do know from my old drag racing days that big power gains are easy in the beginning but you quickly get to a point where it takes thousands to go even a little faster.
I agree - a lot of Viper owners have excess $$ to pour into their cars, and the limited aftermarket vendors seem to capitalize on this. Some of it can be explained by the relatively low # of Vipers, so the market to recoup any investment is limited.
For its displacement, the Viper is a poor performing engine in terms of generating HP, but it is because the stock heads' crappy flow. Unfortunately, the only aftermarket heads that I am aware of are the Strikers, and at ~$6500 (including Jesel rockers), the cost per HP is not great. I'm not knocking the excellent product, but the bang for the buck isn't there. It's not like the Corvette camp that can choose from 10 different LSx heads manufacturers, for under $2500/set, or twin-turbo kits for $7k.
I don't understand the reluctance of the cast-piston owners to go with the Roe, Paxton, or even TT. Z06's have a MUCH higher CR and there are a ton of them running FI and putting down 550-600rwhp on cast pistons. For the $$, you can't beat FI, imo.
550-600 is fine on a cast car...more and you never know.
id call greg good before you spend the kinda cash its gonna be for the strikers. he can do a dang good job on your heads for im guessing half that cost.
Going to do all ten? You could just do one side this year and save 50%. Ah what?....really, all ten every time?...oh....never mind.
