Help: Jerico transmissions or any advice
Tom and Vipers
Jeannette, PA 15644
You might want to contact Tremec or whoever makes the T56.
There is a slight chance they may have some advice or insight into these failures.
For one, rally guys use Mobil 1 15w50 where Dextron is used in transmissions. However, the synchronizer material must be compatible. (I believe the later material is the compatible one.)
bitya
manitowoc wi. usa
Heat will destroy anything. Have solved many trans & diff problems by install coolers on them. The cooler setup from Chrysler works and can be adapted to anything.
Tom and Vipers
Tom and Vipers
Jeannette, PA 15644
Also try contacting D-C because they are probably interested in failure modes - especially at high mileage.
Don't take no for an answer when talking with D-C since there will be probably 6 departments you'll have to go thru to talk to the right people.
TOOOFST
Barrington,il
E-mail Paolo Castellano,check posts a page or two back,had one in his 96GTS.When it was running,its impressive.
BarryLB
