ruf575
I was bleeding my clutch fluid '94 Viper (15 year old fluid). I accidentally let the fluid reservoir run empty
. I even talked to Chuck before doing this, and did exactly what he said to do. I still got this wrong
. He told me that I would be chasing my tail if I did get it wrong "he is/was right"! I have pumped or my buddy has pumped quite a bit on the pedal 25-30 pumps per bleed. I still have a clutch that is soft and/or bleeds down after a few minutes not completely but it is noticeably softer than just pumping just once or twice. And now there is some squeaking from the inside the transmission and right where that small black (plastic) slave cylinder (i know the slave is inside the trans)looking thing it's right under the brake master cylinder/booster coming out of the firewall. I don't know what to do know? Any help would be appreciated. Thanks
