How much does it run to get a set of turnout tubes for belanger headers?
DrumrBoy
GA
If you find out, please post the answer, I need exactly that part as well. Left a message earlier today but haven't made real-time contact as yet (still early in AZ thouugh).
Catwood
I paid $100 per side to get them custom made adding my HF metal cats at a local muffler shop that was race friendly.
I did the side sill removal myself and drove ther with the pipe exposed. He made it the same as the pipe that came off so that I could use the old one as an Off Road Pipe.
YMMV
Vital Velocity
Dickinson, TX
Yeah ill be going without the cats on mine, just need the turnout.
On a side note, does anyone know how bad this will effect the header? Seller says it has the dimple for clearance on the passanger side?
ViperTony
Clearance from what? I'd be more worried about trueness on the flange surfaces. Depending on how they were installed overtorquing the bolts on the flange surfaces, namely the collector and Y connector flanges usually leads to leaks in those areas. Are those fresh Jet Hot coated?
Vital Velocity
Dickinson, TX
This is what he said
Belanger Headers 1996-2002 Dodge Viper
Dyno tuned and track tested long tube Tri-Y Headers.
Laser cut 5/16" header plates.
Mandrel bent 1 3/4" port matched D-ported equal length primary tubes.
Primary tubes constructed of
aluminized tubing run 50% cooler than stainless steel stock exhaust.
3" collectors.
Some scratches and NOT ceramic coated
BarryLB
