How to set up Arrow roller rockers???????
1TONY1
Dalton Ga. (Chatt. Tn.)
TDC for each cylinder, Zero lash between the rocker and push rod and then do your turns. I think Arrow says two turns. Mine are on about one turn and make a little noise at cold start.....I am going to try 1.5 turns. You did change pushrods ?
fe155
San Diego,ca
I have T&D's did the one turn got noise did the turn and a half now its quiet , just make sure your oil is still flowing to the shafts by cranking the engine at the starter and looking at the rockers
V
VIPER BAZ UK
ENGLAND
Cheers guys all done and running again so far so good.... :usa:
It had new push rods,mopar valves+springs ported&flown heads 2000 headers blah blah blah..... :2tu: :2tu: :2tu:
luxurytfirstravel
