mrbob
should i install the heat shields or not , i removed the converters and have 3" side exhaust . or should i make a shield for the heater box and not install the shields. thanks to all
My opinion always has been, install the heat shields even if the headers are coated. I can do nothing but help keep from melting stuff.
--FQB
You are going to get a lot of mixed reviews. I have run my car on the track in temps over 100 degrees with no heat shields and nothing melted.
How's that work for you sitting at a traffic light idling for 5 minutes every 1/4 mile under those same conditions? I mean the same ambient temp condition, not the fact that stuck in traffic you have zero air flow. That part is different.
Has worked fine for at least a year and a half. I have monitored my plastic parts under the hood checking for wear or melting, nothing yet. Now I do have to change my brake fluid more often though.
I'm running the heat shields on coated Belanger headers. I'd use them.![]()
I have a supercharger generating extra heat in the engine compartment. Every little bit helps.I was told with Belangers you don't need heat shields..
Part two is heat period. Heat dries out plastic. Think dash boards in the southwest. By keeping the shields on, you allow less heat to soak into the plastic components, thus giving a longer life to your underhood components.
Heat does not dry out plastic. The environment consisting of heat, UV, ozone and so on break down and disrupt/modify the polymer chains on a molecular basis causing the plastic to loose it's original physical properties. The good news is that underhood non-metallics are made from polymers that are either minimally affected by the previous list I just gave, or if they are, the change to them is not a significant as say your dash is.
Thanks for the education Dave!
I guess I stand corrected!
