Maximum HP on Gen1 Crank, Pistons & Rods
Stahlhart
Hi,
what´s the maximum HP you guys made on stock Crankshaft, Pistons & Rods on a Gen1 RT/10?
I made nearly 800HP (@Crank) with built cylinder heads, headers, camshaft, roller rockers, Paxton (@ 8PSI), 70mm throttle bodies, polished & modified intake manifold (rolling thunderz),... The 2 Walbro´s 255 ran with 99%, so we "just" reached 785 HP @Crank (Superflow SF883 E).
With the two Aeromotive (Stealth 340) and E85 gas, I want to gain more Power. What can you recommend on the Stock Crankshaft, Pistons & Rods? Heared something about 900 rwhp???
Thanks and regards
Jürgen
Roy
Netherlands
I can't help you at all, but you sound very German, where are you located, I'd love to see your car in person...
CWhiteRun
Has Left the Room!
Dothan, AL
Stock crank can go to 1200 easy. are you using the stock pistons? They are forged, but if you want to go higher than 800-900, I would recommend going to after market pistons/rods.
Stahlhart
Stock Crank without fine balancing to 1200? Sounds great!Do you mean 800-900 rwhp or @crank? I know they are forged on the Gen1 so whats the problem with them?
Jürgen
CWhiteRun
Has Left the Room!
Dothan, AL
No, it needs to be balanced properly to go to 1200. Pistons and rods should be changed out to go HIGHER than 800 or so at the wheels.
