O2 Sensor Part Number
HOdbleFman
Hurricane, WV
I need the part number for the factory O2 sensors. Also, does anyone use the Bosch sensors? If so what part number do you use for the Bosch sensor for a '98. I've got two new ones but the connector doesn't match the stock one. One of the clips is offset a bit. Can I just grind the notch off and use the one I have? Are there many differences in OE style sensors?
venomblue550
DO NOT use Bosch sensors, becuase for some reason your car is not gonna run right, i had that problem, so end up had to switch back to OEM sensors..
xeng yang
