Today I got started on my NA heads and cam project. No big surprizes during disassembly. The only broken parts were my plug wires - almost welded to the plugs and pulled the wire right of off the boot. I know I was warned but geez those things are tough. Had to be creative to get the intake off as most tools will not get down into lower allen heads - universal worked fine. Here are some pics. Question for Tony..... How did you "pin" the crank as discussed from the Wizard? Heads should be off tomorrow.
Here are the build specs:
Comp Cams - Custom Grind 3634/3635 + 4
(232/236 Dur at .050 .601/.606 valve lift on 1.7 Rollers
Manley Valves SS: 11643-10, 11644-10 2.02 and 1.60
Harland Sharp 1.7 rocker arm
Isky springs 8305
Isky valve locks VL10-5/16
Comp Cams Retainers 1732
Comp Cams Spring Cups 4772
Comp Cam push rods TBD
Head work: me and Greg Good
NEW PLUG WIRES, HA!
Isky springs 8305
NEW PLUG WIRES, HA!
