Some Performance Help!
crow_48032
Michigan
I'm looking at buying a 2000 RT/10 or GTS.
Which mods would I need in order to run a consistent 11.5 - 11.7 with me being an average driver?
Would a cam, headers, and catback exhaust do the trick? If it would, could you guys give me some brand names to go with and to stay away from?
If those mods aren't enough what else should I go with?
Thanks for all the help!
Joseph Dell
Atlanta, GA 30338
Good tires and a line-loc should get you there... heads and cam would definitely do it. or NOS... but tires make all the difference in the world.
JD
plumcrazy
ALL OVER
be a better driver and no problem. i know there are a few guys running those numbers...NOT me though..lol
STUGOTS
NY/CT
I saw a post maybe 3 weeks or so ago 11.6 @ 124+ MPH BONE STOCK.
Schulmann
Canada
Buy either a model before 2000 (they have forged cylinders) or after 2000 (they have ABS). Model 2000 is not the best one.
opnwide
austin tx usa
buy a line lock and with a little practice you'll click off a 11.70 like me. Practically stock! on Pilots!
99 R/T 10
Enterprise, AL USA
It's a piece that allows you to lock up the front wheels while doing a burnout and not have to worry about holding the gas and brake pedals at the same time.
Randy
Earth?
Actually, someone recently mentioned that the 2000 model had the highest bone stock horsepower numbers. It all depends on whether you are planning to do mods to it or not. Granted, "crow" sounds like he/she is planning on modding it, so your advice might still apply, as reportedly the 2000-2002 *pistons* (not cylinders) won't take as much boost (be it NOS, turbocharging, or supercharging).
zeeshan_k24
