Steering shake issue
Proshop
Hopefully you guys can help. 04 30k PS2s. When I hit a compression joint in the road or a sharp bump in general I get a loose steering wheel shake. Its just started a month ago. Im guessing that it might be a bad shock but im looking for some conformation or guidance to look elsewhere .
Thanks.
bluesrt
check the front end for loose parts-check swaybars-check shocks-check tires and alighnment---anything that is even slightly lookin worn needs to be replaced on a car of this caliber--if it is all there it should be good
CWhiteRun
Has Left the Room!
Dothan, AL
Check your ball joints and tie rod ends for sure. Is your car lowered? If so, then you might need a bump steer kit.
P
Proshop
Look at the rack & pinion mounting locations
I am installing a paxton now and had to remove the rack bolts and spacers which all seemed ok.
So no chance on it being a shock? I will put it on jack stands and start shaking crap until I find something loose .
