thermostat removal
BUD
Sugarland Texas
Anyone ever just take out the thermostat? My snake runs hot, and here in Texas you almost never need heat. What are the pros and cons of just taking it out?
Qualitywires.com
Louisville, KY
The themostate helps collect heat from your engine. From what I understand, it slows the water down so the heat can transfer to it and plus it helps regulate the engine temp.
red98GTS
Arizona, USA
Don't remove the thermostat. Big mistake.
pete the ex glass guy and hot rodder and happy with stock thermostat in Arizona heat
Snakester
Morgan Hill
I was going to swap in a lower temp thermostat, But it looks like a pain having to pull the intake and injectors, and needing a new seal/gasket.
I added a Fluidine radiator and it runs relatively cool even in stopped traffic on a hot day.
-Dean.
Johnkato
