I found a 10 throttle body setup that removes the viper intake for extreme applications. Who would use such a thing? I can imagine a bad ass TT setup taking advantage of this.
Here is the link:
http://www.giwasa.com/viper_10throttles_frameset_gb.htm
Here is the copy:
10 THROTTLES KIT BODIES
GIWASA built a 10 throttle bodies kit for RT10 & GTS , same as the GTSR unit in 62mm(2,48in diameter) this unit is originally for the GTSRR 1200 HP GIWASA
Size & fittings are done for take place of the original intake manifold without any modifications , its a ready to go turn key system .
Fittings are done for :
- the original throttle cable
- the original wiring for the injectors
- screw for the original gasoline hose
- for the electronic idle valve
- for the heather vacuum pipe
- the map sensor connection
- the original vacuum tube from the brakes
note 1 : with the GIWASA 10 throttle bodies & original engine the idle speed nivel is stable on 700 rpm .
note 2 : no body modification is required for the GIWASA kit mounting , original hood can be conserved .
GIWASA kit is built around 2 main parts , one set of 5 throttle for each side of the engine . All the butterflys are hermetic bearings mounted , its a guarentee for many miles of smiles . They are extremly wear resistants . Equilibrating the different bodies between them can be done by right/left scews also mounted on inox rod ends by aurora
Each 5 throttle part is monobloc to avoid thermical dilatation who can make idle perturbations , special fuel rail and new size injectors are delivred with GIWASA system
the ECU-PCM upgrade is include in this system .
note : new injector sizing & ecu upgrade are done for stock engine , on request dedicate special sizes & ecu programming .
CARBON AIR BOX GTSR lookalike is delivred with the kit , a flat big size K&N filter is fitted on top like on the INDY CAR or F1 engines
Here is the link:
Here is the copy:
