I don't know all I would like to about the lifter situation. There have been a good number of aftermarket lifters that have failed. This info comes from several tuners going back several years. Axles coming out is the usual culprit. Right now I don't trust any of the aftermarkets so I tell people to get a low mileage set of OEM 96-99 lifters because they have a good track record. The 2000-2002 Creampuff bleed down lifters IMO aren't good for anything other than use with the stock camshaft and stock spring pressures.
I realize that an aftermarket company supposedly sells to Dodge, but there is an inconsistency in durability between what Dodge puts in their Viper engines and what the tuners are getting. I "think" the quality control is better on the lots going to the OEM. Just a guess. My info is that componies like Clevite and FM source their parts from various third party manufacturers then package/sell them. If so, then when they change vendors, they could be getting a wholly different lifter, quality-wise.
The Viper is supposed toshare lifters with the 360 Dodge Magnum. At least they show the same part number in the aftermarket catalogs. Crane Cams offers a top shelf lifter for the 360 Dodge Magnum (which oils through the pushrod like a Viper). It's expensive, but it may be a good alternative to rolling the dice on an FM or Clevite.
