ACR steve
Ok changed my brakes last night. Doesanyone know the torque spec of the 2 bolts that attach the caliper to thespindle?
Not to question, but my service info says 55ft lbs. We are talking about the caliper mounting bolts, right? This is an 11mm x 1.5 bolt into aluminum. -am I under torquing?85 ft/lbs for the caliper bolts.
Gotta take 'em off to change rotors.....................ain't it....Were you doing something else to the calipers that required you to take them off?
This is a timely thread, as I changed my pads and rotors this weekend as well.
Unfortunately, NTB had over torqued a lugnut when they put on my new tires and the stud broke when I went to remove the lugnut.
MY QUESTION:
Isn't there supposed to be a divit behind the hub so yuo can get the old stud out and the new stud in? I cannot find it for the life of me!
You don't want to "pull" a new stud in anyway, you need to pull the hub off and press them in and out, then re install the hub. If one was bad I would suggest doing them all at the same time because chances are good the rest are also stretched.
