Fire Supression System
KaiPL
Salt Lake City
Here are some pictures of my new fire supression system:
It is a 10 pound Halon system.
It is actuated by a pull handle located in the center console.
There are three nozzles: 1 in the engine compartment, 1 by my right knee, 1 in the center console. The center console nozzle is automatically actuated if the temperature exceeds 200 degrees. The system came with aluminum tubing, but I replaced it with flexible braided stainless, as I figure that flexible tubing is less likely to crimp and get blocked in the event of a crash.
GR8_ASP
Why do you have your brake vacuum line covered with what looks like an insulator/heat shield?
SRTRICKY
Canada
Nice set up...on another note...where did you get that oil cap from looks wicked!
Vipera Russelli
Looks good. I'm seriously considering ordering the same set up. Do you remember the tubing size and type?
Thanks for sharing.
BarryLB
