94 RT/10 Black MAMBA
A lot of people seem to think there is a problem with the Gen 1 head gaskets.... Wrong, the head gaskets are a symptom, of the REAL problem - which is the steel cylinder sleeves were poorly designed and they slip!!!!!
The solution is a Arrow rebuild...which I had done (lucky me) and here is what they did (they sent me this "Failure Report" as they call it):
ARROW RACING
ENGINES INC.
FAILURE REPORT
RV102991
Upon receipt of your engine, we found several things wrong. Both cylinder head gaskets were leaking coolant and the thermostat crossover was leaking too. The main housing bore was out of spec from .0001" to .0003" and had to be align honed to repair it. The flywheel also needed to be replaced.
The block was sent back to the original manufacture for counter boring and redecking.
The engine was then reassembled using all new parts including the crankshaft, camshaft with lifters, piston/rod assemblies, cylinder liners, timing chain set, front cover with oil pump, thermostat, water pump, rod and main bearings, spark plugs and wires. With new gaskets and seals, the rebuild is complete.
The engine was then sent to our dyno shop for a two-hour break in period with three W.O.T. power runs to confirm the engine met the rated horsepower and torque numbers. These were both exceeded @ 425HP and 510# of torque. A cylinder leak down and compression test was preformed, and a special oberg oil filter was inspected and after a final check for any external oil leaks the engine was prepared for return shipment.
NOTE: The second paragraph...remachining counter bores. This is the major work required to correct the design defect of the cylinder liners. It provides a means to lock tem in place so they cannot move and cause any future failures.
Look at all of the other parts that were installed by Arrow...Nearly everything in the engine is new!
I hope this helps clear up the myth that you can correct this problem by replacing the head gaskets only. That is like puting a band-aid on cancer. You didn't cure the problem.
ARROW RACING
ENGINES INC.
FAILURE REPORT
RV102991
Until substantial proof of bad sleeves can be proved, don't be goin' off on a rant that all Gen. 1's are gonna crap out!!!!!!
