ChoiceViper
Re: VIPAIR™ Dyno Results on 99 RT 16 RWHP!!
600th post!!!
![headbang :headbang: :headbang:](/vca/styles/default/xenforo/smilies/headbang.gif)
600th post!!!
Shelly,
Let me try to understand your view of "what is good enough for the GTSR guys....".
Without the details of why they did what you are comparing apples and oranges. Read the article, different engine, different body, different engine placement etc.. So you point to the fact (that isn't mentioned in the article) that they use a different induction system as proof Vipair works. Well since they changes everything else, how is that proof that doing something remotely similar on a stock car is relevant.
Boy are you one confused pup.
Whaddo I get? Whaddo I get?![]()
Was he serious?
Did I actually win exhaust tips? No B.S.?
If so, WOOOOOOOHOOOOOOOOOO!!!!![]()
[tear in eyes]I've never won anything in my life.[tear in eyes]![]()
Oh wait.... Do I have to buy a Vipair first?![]()
Dave
Was he serious?
Dave
Dave
Congrads.You won a new set of awesome looking tips for your viper.No need to purchase anything,just give me your shipping info and your tips will go out monday![]()
I wish someone would shoot this in the head.
Thanks for the additional tests FE.
I think they are pretty conclusive, but I am sure there will be some that disagree.
So Shelly, what does your logic say about this test? Please try and come up with an original thought and don't just cut and paste the old "if it is good enough for GTSR....". I can still get you some magic HP beans.
So, is someone going to use that handy dandy temperature sensor that is built right into the airbox to ascertain the difference in inlet air temperature. A check at a few higher speed points with similar ambient air and coolant temps would suffice. I am betting on less than a 10 degree F difference ( I am betting on a 20 degree delta T across the radiator when at speed). Worth in the neighborhood of 5-10 RWHP, but only due to the temperature. No ram effect at Viper speeds.
But, since it is so easy to measure the temps, why are we speculating on a web site? Just make a few measurements and post the results. The horsepower effect can quickly be calculated once you know the temperature difference.
Vipah and 2FAST4U,
The obvious thing that you fail to understand is that there are variances in engine bay temperatures at different speeds as surounding factors vary
