viperbob
Needless to say, O2 sims will be needed when going catless, right?
Is the sound very much louder when I remove the high flow cats and go catless with my corsa track?
YES!!!! But it sounds good. It took a little getting used to,but now it seems normal. You can cruise and its noticeable but not abnoxiuos, but once you are over 3-4K rpms, it roars like its **********. I love it. You will also gain a little power and torque by removing cats and going catless.
When I had RT cats and buddy was catless, he had me on the dyno by about 7hp up top and about 20-30 rwtq in the fat section 3-5K rpm range.
HAHAHA!!! WRONG - it IS abnoxiuos and it was like 25 hp in the 3-5k range too![]()
My buddy tried 02 sims and they didnt work. So he zip tied his up and its been fine. SO I did the same thing. I left them plugged in and just zip tied underneath to the wire loom. Works fine and no check engine light.
I've been a little confused about the function of the secondary 02's on the viper for years. A while ago a friend of mine installed the complete catless Belanger exhaust on his <u>supercharged</u> '97 GTS, leaving the secondary 02 in the place and it never set on 02 code...I would have thought they would set of a high 02 reading code, but they never did.
You are right, that's unusual.
The secondary O2 sensor is there as a requirement of OBDII, it is used to compare the O2% before and after the cat, to make sure that the cat is working (or that it is there!)
Taking it out does not affect performance in any way, just the obnoxious idiot light comes on.
On my car I first installed the off road exhaust, and the light came on (worth a try!!) then I slapped the sims on, and problem solved.
Another Corsa question - should I get the 14174 (for high flows) or 14176 (for stock cats) if I plan on keeping the primary pair of cats? I was told I should go with the one for the stock cats since it will 2.5" all the way vice 3" with the other one.
This is the cheapest I've found, I ordered a set last wednesday....
http://www.lmperformance.com/7150/63.html
1,177 shipping included! can't beat that!
On a sidenote, what do you think of their clutches?? SPEC brand...? my clutch is about to go, I need a cheap replacement to hold me over no more than a year max.
Man, that is a cheap price for a Corsa...are you sure it is legit and not a Made in China ripoff?
Thanks Zorroespanol and let us know when it arrives.
I got the Corsa Track installed aboout a week ago. I love it, sounds great...........Everyoen said there is a drone, i dont hear any drone at all. I love it.
