Big jugs of Mobil1 15W-50 at Wal-Mart
I was walking the lubes aisle this evening and found 5-qt jugs for the first time in 2+ years! Just under $28 per jug and quite a bit less than quarts. 0W40 was priced the same.
Walmart is usually one of the first places I go for oil as they have always carried Mobil 1 for a pretty good price. I've never had trouble finding the bigger jugs, though I haven't been in a while either. Finding the right weight has been a challenge from time to time though.
Bonkers
DelaWhere? USA
Ive also never had trouble finding 15w-50, even when stocks
went down, so i am guessing its a regional thing. Wish it were
easier to ship, i could have made a fortune in the Pinch...
2 years ago, I had to go to4 different Walmart in the greater Indy area to purchase 18 of the 5 quart jugs on Mobil 1. 0W-40. While loading my cart at the last store, I noticed a manager tag on a person in the old area. I inquired about the seemingly sporadic stocking of this oil. She agreed that it could be a hit and miss deal...stating that stores that sold more, got more...but on no particular schedule. Curious. Fact or fiction?? Who knows ??!!!
XXXX
RockHill, SC
Order online and get free delivery. They pull stock from whatever store has the item. Otherwise, expect about 50:50 unfortunately.
Bonkers
DelaWhere? USA
I usually run either NAPA Gold, or WIX filters. I sample at every change, or once a year, whichever comes first.
Thats such a bad idea, im really surprised its coming from
you Dean. Wix and Napa filters only have a 90psi bypass
for a motor with a 110psi startup. To each their own, but
running unfiltered used oil through the block makes my
skin crawl.
If your car is hitting 110 psi, then there's an oil pump relief spring problem. The way people throw away hardly used premium synthetic motor oil and obsess over filters just floors me. To each his own.
Bonkers
DelaWhere? USA
The Wix has a bypass pressure of 8-11 psi. This is the pressure differential across the filters' element.
Thats the filtering pressure, im talking about the
emergency Internal Relief Valve.. The bypass is on the top
of the filter, Wix, Napa, Mobil, Fram, ect... are all 90psi
which is the standard operating start up pressures of
95% of all motors made. The Viper V10s (and some
say the Magnum V10s too) have a cold oil start up
pressure of up to 110psi, especially if you are running
the proper 0w/15w oils in the cold. If you are running
ANYTHING but a Viper Filter then the few couple of
seconds after start up you are running unflitered, raw
oil directly back into the system until it self-regulates.
This has become one of my biggest pet-peeves here -
the difference between a Wix and a Viper filter right now
is $5.41 and yet so many here (some of the very same
people who gave me shit for YEARS because of my lack
of income,) think that Dodge is somehow trying to rob
them of their retirement with a filter specifically... and
only... designed for their precious cars. Its infuriating...
From SRT Direct: (you know unlike the guys who work on
their cars in their driveway, these are the HIGHLY educated
men and women who actually designed and built the motors
"The SRT oil filter for all the past engines and the new 22mm
inlet SRT filter for the Gen 4 and beyond engines share the
same characteristics.
We worked with many of the filter suppliers to get the best
features. Some fell out for various performance reasons but
we ended up developing the current SRT filters with one of
the mainstream manufacturers (it is different than their
commercial offerings - or at least was when we developed it).
The high flow oil pumps in our large engines (Viper is the
biggest) can overpower the internal relief valve. When this
valve opens it allows some of the high pressure dirty oil to
bypass the filter element in order to keep the filter from being
damaged. The SRT filters do indeed have a higher differential
bypass valve to make sure all the oil delivered to your
powerplant is clean. The housing is slightly thicker than many
of the brands out there to handle the pressure but is not the
thickest. The real thick ones failed our development testing
(fractured at the crimped flange). The media used was one of
the latest synthetics that allowed very fine filtration, more
debris capacity, and much lower restriction than our standard
Mopar filter (and just about every other filter out there). The
final result was clean oil to your Snake, all the time, with more
pressure to the internals where it is needed. I would fully
recommend using this filter in your beast, I do in mine.
Hope this info helps."
Thanks for that. I'll keep right on doing what I'm doing.
I had my engine honed, re-rung and installed new valves in 2020 at 36k because I stupidly left a paper drip towel in the oil entry galley while installing new timing cover gasket and doing a full chassis detail. I forgot about it and the cam seized while idling in the driveway. My engine guy does a lot of vintage sports racing car and TA2 motors. He was very impressed with the crank, rods and pistons, especially with my history of extended M1 15W-50 drain intervals and ~5000 track miles with only an 8 quart pan. He installed the WIX XP filter on my engine because that's what he installs generally and that's what I use now.
Steve M
Dayton, OH
Pretty sure Wix makes the Gen 4/5 SRT filter.
Check out the Wix 57063.
Someone on the other site cut open a few different filters and found the following:
Mopar MO-041
22.62 PSI average (sample of 3)
38N (Spring force)
17.3mm (Spring diameter)
21mm (Spring free length)
8mm (Spring compressed length)
69 (pleat count)
Wix 57063
23.45 PSI (Calculated bypass)
38N (Spring force)
67 (pleat count)
Source info here: https://driveviperforums.com/forums/threads/29664-Oil-filter?p=455659&viewfull=1#post45565
Bonkers
DelaWhere? USA
Yes, i think Wix is the manufacturer mentioned above,
but if you believe anything coming off that site, then
i really have nothing more to say to you.
Lots of videos etc out there testing filters. Here's one https://youtu.be/rqDjCzyYUOU?si=YvTkT-2QCD3kmSRp
They are tons of variables involved.
Without cutting open the a statistical amount of the same filter and manually checking them, measuring oil pressure throughout the rpm range and at different temperatures, manufacturing tolerances, etc of different filters. This discussion becomes an academic one with people just stating what they read or were told.
Slybri
IL
Up to you what you believe or don’t; I posted that data after dissecting potential alternative filters back when the MO-041s were in short supply.
Also keep in mind, oil filter relief valves work in differential pressure (i.e difference in pressure between input and output sides of the filter). It has no direct bearing on the actual oil pressure. In the case of the Viper filters, they have ~23 PSI diff pressure rating, so on those 90+psi startups, the filter is much less likely to bypass than if it had say for example an 8 psid rating.
Have any questions on the testing or PSID? Let me know…
Sly
Bonkers
DelaWhere? USA
This is what i believe - Cheap assed Daimler wouldnt
have spent a penny on development of a new Filter if
it wasnt needed... especially considering they had a
Filter already designed with a contracted other company
(Mobil.)
Also i dont believe an amateur, no matter how well
intentioned, has the equipment or skill to bench test
a dynamic flow rate on something as complicated as
a Viper V10 dealing with all conditions and environmental
variables (ie, weather, parts, and wear.) Bench testing
for PSID through a pipe in a garage does not give an
accurate understanding of what the differential is in the
real world, but even if it did, a 20psi differential with
15w-50 in 30d weather implies the relief valve could stay
(at least partially) open indefinitely.
And this isnt personal - its the same beef i have with
every armchair automotive engineer. While i enjoy the
entertainment of some guy doing "technical" experiments
in his bathtub, the truth is that outside of a controlled
laboratory you are still at whim to your own personal
biases. I watch those youtube "comparisons" and think
of all the ways i could manipulate them to make Amshit
look as bad as it is intentionally, not even speaking of
the unintentional biases that could happen.
You want to change my mind on this issue, bring me the
the results of a full-fledged MIT-level study showing me
that the 110psi relief valve is worthless and then... only
then... will i agree that maybe the $4.78 savings on the
Wix filter is worth it...
  • Like
Reactions: AJT
redtanrt10
Dana Point CA
Dean, just seeing this post and remembering a prior post about you having difficulty at you local Walmart find Mobil 1. Not sure where in TX you're at, thinking New Braunfels or similar? That's metro market. I was real surprised since I can always find 10-50 at at Walmart.
Hey the best deal is in the Spring/Summer when Mobil 1 has their rebate program. I get the jugs at $26-$28 and then there's a $5-$8 rebate per jug, limit 2.
When I finally found the M1, I couldn't find anyone in the store to sell me a hunting license in the sporting goods section three rows away. One person in the whole store to do that and he was "on his lunch break" at 6PM.
SA HEAT
Bulverde, Texas
Dean, it's a little drive for you but the Bulverde/Spring Branch WalMart on US281/Hwy 46 almost always has 15w/50 jugs in stock.
Thanks, but I'm good for another year+ with my 2 jugs when I decide to change this pan full out. I pulled a hot sample last week and should get my results late this week.
Steve M
Dayton, OH
It's a slightly longer drive for you to Ohio, but my local Walmart also has big jugs.
Of Mobil 1 15w50 that is.
No members online now.
Johnkato
