Is This A Door Sag/Hang Issue?
-TRQuixote-
MN
Should be piecing together the purchase of a new (to me) 97 GTS this week and going over some pictures. Does this appear to be just wear and tear, or is this maybe a door issue? The weatherstrip isn’t cheap and from what I see there’s only one source these days. Thanks!
Hard to say, but at that kind of age it's probably a little bit of both. I know the seals on my 04 have split in several places, even with the doors being well aligned ever since I bought it. I've also put quite a few miles on mine though, so I may have more door cycles than most. You figure that car is nearly 30 years old at this point, so any soft parts surviving in good condition is more of a bonus than an expectation for me.
So even when I bought my car 11 years ago, I did go and perform a slight adjustment. fairly simple to do, all I did was use a jack and made sure I marked whatever shims were removed.
Tom and Vipers
Jeannette, PA 15644
You should be able to feel sag when you open and close the door. There are issues with the door panel rubbing which makes it difficult to adjust the door accurately. To me it looks like sag. That area you don't normally brush when you get in and out.
-TRQuixote-
-TRQuixote-
MN
Would that be pretty straightforward for the average person to resolve? Getting ready to hopefully take delivery of the vehicle.
Are you Mechanical at all? How do you even know you have sag?
Its good to learn but dont look for Phantoms. Wait until you get the Car, we are always here if you need help.
Bill W
Greenville, SC
Not sure if it's a door sag issue. I had a similar tear and used high-quality black electrical tape to fix it eight years ago. Still looks good, and with dozens of people checking out my car over the years at Cars & Coffee (and a few other shows), nobody has ever noticed it.
GTSnake
Motor City
Most probably. Both my doors are a little misaligned with the passenger side being worse. My driver side actually fits a lot better. Surprising since it's used 95% of the time. I've tried to adjust the pass side but for some reason it still doesn't fit that well.
At 26+ years old, my '96 had this problem on both doors. I removed the door panels and adjusted each hinge and striker plate so that after a button press, the doors pop open about 1" - exactly like they did when the car was brand new. They closed easily, snapped firm and the door gaps were perfect. I reinstalled the door panels and they started dragging again so I had to forsake exterior panel alignment for making the door panels fit the hole. Now at 30 years old, it's gotten worse again.
I've become convinced that the door panels have lost their original molded dimensional contours and are the primary source of of the dragging and interference fit at several locations - particularly the carpeted lower sections. How to fix that? I'm still struggling for answers.
viper426
NJ
I've heard that before I hope one day in the future to get one I've owned classic/muscle mopars in the past and on my 67 coronet my doors were sagging so I know it *****.Good luck with with you're viper!
VIPER PIT
Boerne Texas
This might freak some of you out. But on my 98 GTS since new, I always felt a little bit of dragging along the bottom where that picture shows and also as you go up toward the jam striker. Since the car was new, and the door was alined perfectly on the outside, I pulled up the weatherstrip to study the substrate there. I then took a Dremel tool and a small cut off wheel and trimmed that fiberglass material ever so slightly. Some areas a 16th of an inch up to an eighth of an inch in another area and reinstall the weatherstrip. Never had a problem after that. The door panels with that carpet on the bottom of them are kind of bulky and the tolerances between the panels as they’re made is not that consistent so I’ve seen many cars rubbed like that. I would consider it normal.
doctormosfet
Mahopac, NY
Whether it's from door sag or not, you won't need to purchase a new door seal to fix that hole. As you already know, very hard to find and you'll get bent over a barrel for an elaborate piece of foam. Get some weatherstrip tape from Home Depot and some 3M weatherstrip glue and patch it up. I had a very similar-sized hole on my driver's side and patched it up that way. Works like a charm and the weatherstrip police haven't deported me yet.
-TRQuixote-
-TRQuixote-
MN
What kind of weatherstrip tape? Im seeing a lot of random options, but not a good black one that looks like it would work. Any chance you have a link for reference?
YYELLOW
