Split Second controller and fuel pumps
JST2CRZY
Deland, FL
My 96 gts died in traffic a few days ago and would not restart as I had no fuel pressure. It has 3 in tank pumps on a hanger. There is no power to the pumps or relay. Checked all fuses too. According to tech support at Split Second, the pumps are controlled by their unit. There is power coming out of the box and through 3 15a fuses attached to 1 of the wires coming from the unit then the wires are buried under the pcm.
It seems to me that there is a broken wire but wanted to ask if someone has had the same setup/issue and there was anything else it could be?
Also, I was told the the box should not be mounted in the engine bay because water intrusion and heat will kill it. Thoughts?
BarryLB
