autoreality
I just bought a 97 RT/10 and noticed after I got it home the drivers and passengers windows didn't work.
With the ignition turned on I can hear a slight click in the window motor areas when I push on the switches.
I started by pulling the center bezel off and testing power to the switch which I have. (12 Volts). I then tested the window switch according to my Viper service manual and it checked OK.
I then took off my door panel. I removed the connector from the regulator and also got 12 volts and -12 volts with the meter at the connectors when I moved the switch back and forth. This morning I pulled the window motor and regulator out convinced that was my problem. Hooked it up to a marine battery and it worked up and down just fine. I plugged the regulator back into the connector on the car and it won't move.
Unfortunately, I don't know of any previous problem with the windows since I just bought the car and can't get a hold of the previous owner. What am I missing? Is there possibly a ground problem somewhere?
Here.
