You do know that you do not want to be rotating the crank too much without dog bones on the block surface. You can lift the cylinder sleeves.
Gen-2+. Interference fit liners. They normally won't move short of cutting the block in half, lol.
I've been reading this thread since it started... Thanks for all the photos, sorry this happened to your car J. So nice of everyone to jump into help.
If one of you guys get a chance could you answer a couple of questions? I really want to understand what went wrong as this thread evolves.
If I understand Dave correctly, sending out a dirty oil sample to blackstone after every change would tell a story about abnormal engine wear before problems begin... Correct?
How many samples until you get a number that tells you how the engine is actually wearing? If buying a car would one sample be a good diagnostic practice?
This is the first time I have heard about oil samples being sent out. IF you can get that much information out of these tests why aren't more people doing this? We should try for a club discount... the analysis can tell you what type of material is being worn in the engine. tells if its could be bearing material etc.. a sample analysis is here: Gas Engine Sample Report 1
Was the filter ever opened to see if that chunk is trapped in the filter? IF the chunk made it to the bottom of the pan wouldn't it have been stuck to the plug like the smaller pieces rather than flowing out with the old oil? if it was small enough it might get stuck to the bolt but could easily pass it and float thru the engine
What is a dog bone in an engine? rod
Last one...
What is that rusty looking goo and what is it doing in J's engine? GUNK, its in a lot of engines.
I thought the same, but, Tatar has a very different view. He sure scared me into always using the stops.
This almost looks like a "spiral" of metal from the balance job was hiding in one of the drilled holes,...
When I bought my '01 in '06 I shortly thereafter put in a new water pump to avoid spinning impeller syndrome. Bought a NIB Mopar unit. Found one of these turnings in the box floating around. The other inside the pump after deciding I should look.
Yup, machining needs an anal post machining cleanup.
Dave......... those shavings are fuzzy. Did you get the rag out of the engine they left in there too?
Or do you keep them in your pocket for good luck or something?![]()
I wouldn't normally disagree with Chuck on much of anything, but he may be mistaken here, or was thinking Gen-1. Gen-2 and newer are thermally interference fit liners. They will not EVER move unless they are defective. Flat out- if they move- your engine needs to be re-sleeved and there is no way around it. I have rebuilt many of these engines and re-sleeved dozens of these cylinders- they don't even come apart when you want them to, lol.
EDIT: The good news is that the journals look fine!
I believe they are talking about a piece that you would bolt under a head bolt to keep the sleeve down in the cylinder. I've never used them on a gen2.What is a dog bone in an engine?
I told him Gen2 and he siad it was still an issue, He convinced me enough that I bought the dog bones from him. For those that don't know what dog bones are, they are a set of ten plates that bolt on top of the block so that when you turn the crank you do not lift the cylinder sleeves.
Dan:
where do you think the culprit went to? There has to be something fairly large hidden somewhere, plus, the piston skirt has not been found?
I'll tell you what, far be it from me to dispute something Tator says. He's a sharp guy. If he says he's seen Gen 2 liners move, then he has. I personally haven't seen Gen 2 or 3 liners move, but I haven't seen the number of engines he has. It's something I will keep an eye out for it in the future.
Jack-
Trust me, you don't need "dogbones" on G2/G3/G4 unless they are wetsleeved in the aftermarket. Hell, I think that dogbones even on Gen-1's are overrated I have yet to see one that actually lifted its sleeves by turning them over- the older engines end up with the sleeves pretty much cemented in place by the coolant silicates anyway by now. On the Gen-1 engines that I have had to pull sleeves on, they DO NOT want to come out. Gen-2 engines require that the sleeves be CUT out. as you can guess, if you can lift a sleeve that should normally have to be cut out- something is severely wrong. You have no solid contact between the liner and the block, no cooling jacket that is working correctly, and impending cylinder damage and detonation for starters.
So far as where the pieces went, the most likely explanation is that they made it out during an oil change. This would be easy considering the pickup where they would likely end up is right next to the oil drain plug.
It is still strange that there wasn't more debris found. In addition, you would not think the skirt debris could have made it through the drain hole. If all the particle matter is gone, what luck. You sort of wonder if the motor was put back together with the broken skirt.
Was going to work on the car last night but got in to late. Going to check the other bearings tonight and see what condition they are in.
Dan, what could have been the problem that caused all of this? Could I miss shift cause this? About a month ago I was on the highway and opened her up. Was in 3rd and went to 4th but I went into 2nd. I had a fast reaction and popped it out of 2nd quickly but maybe it causes this damage then. Could that be possible?
^^^ Nanny crap
Not only the skirt, but, whatever caused the interference. Then, only two small shavings?Where's the missing skirt,that's what I'd worry about.I'd tear down that engine completely. Something is amiss![]()
I think this is where some of the confusion is coming from- where is this missing skirt you guys are seeing? I am looking at the pictures, and the skirts are in tact as they should be, just worn. There is a chunk missing from the pin boss, and dimples in the piston bottom... but thats all?
