Low fuel pressure on start
ninetyfive
Chicago
We replaced the fuel pump and regulator two years ago and fuel pressure issues are back. It takes a while to build up 55psi. Thinking of replacing the pump and regulator again. Are there any components in the pump assembly that should be reviewed?
I ordered the regulator from Havik.
The replacement pump I am finding is a Bosch.
ViperTim
Sweden
Sounds more like the check valve is leaking.
If you stop it for the night and key on the next morning, is the pressure 0psi?
Because that sounds to me like the check valve is draining the fluid of your fuel system and your pump needs to refill & build pressure every single time. Thus I wouldn't believe it's actually a pump issue but more of an internal leaking issue.
But maybe the check valve is integrated into the pump itself, I don't know. I've never had this issue.
ninetyfive
ninetyfive
Chicago
From what I understand the check valve is in the regulator. We tested the pump, it is fine. We replaced the regulator. The issue did not go away. It is so weird. Get it hot, turn off and it starts right backup. Let it sit for an hour or two, long crank. Let it sit overnight, starts right up in the morning.
Another fix would be to put an inline check valve to maintain the pressure. A common cheap fix for the Gen 1 cars that seem to have this issue.
My gen 3 has very similar issues, though sometimes even first thing in the morning it will crank for a while. Sometimes it will catch and run on basically one cylinder at a time until it gets enough rpm in it. Does it make any difference if you feather the throttle by any chance? I replaced my fuel pump/sender unit a while back when my gauge went out and I don't think it's ever been the same since.
I don't think it would make a difference, but I'd wonder if a clogged up fuel filter might do something like that. It would take a little time to get fuel through it, but once the line is at pressure you would assume it would hold okay. Could explain something being lazy to build pressure though.
ninetyfive
ninetyfive
Chicago
Filter was changed 10000miles ago. So i put a gauge on it. Morning it was at 0. Each key cycle built it up 10psi up to 48. Fuel in the rail, physics, and maybe longer injector pulse width when cold might explain starting up cold just fine, even at 10psi. While running it's steady at 48psi. Not sure if not reaching 55psi is another problem or if it's just another symptom of the pump trying to always catch up. Shutting engine off, pressure drops back to 0 within a minute. So next step is inline check valve like @99RT10GTS suggested. So where is the failed check valve then? Pump, regulator, somewhere else?
I believe there is a check valve built into the pump assembly (where the regulator is on a gen 3 at least).
FUEL PRESSURE REGULATOR
A fuel pressure regulator is used on all gas powered engines. It is located on the top of the fuel pump module. A separate frame mounted fuel filter is used.
Fue l Pressur e Regulato r Operation : The pressure regulator is a mechanical device that is calibrated to maintain fuel system operating pressure of approximately 379 kPa (55 psi) at the fuel injectors.
It contains a diaphragm, calibrated springs and a fuel return valve. The internal fuel filter is also part. of the assembly.
Fuel i s supplied to the filter/regulator by the electric fuel pump through an opening tube at the bottom of filter/regulator.
The fuel pump module contains a check valve to maintain some fuel pressure when the engine is not operating. This wil l help to star t the engine.
I f fuel pressure at the pressure regulator exceeds approximately 56 psi, an internal diaphragm closes and excess fuel pressure is routed back into the tank through the pressure regulator. A separate fuel return line is not used wit h any gas powered engine.
The pressure regulator is a mechanical device that is NOT controlled by the PCM or engine vacuum.
I have never had one of these apart, but found the patent online and it did include a non-serviceable filter inside. If the production Viper regs were set up this way, it's no wonder they are failing over time. The regs should pass minor particles to an easily serviceable primary filter so the regs don't choke off. I know that many fuel pumps I corporate a check valve in the discharge nip ple to hold pressure, but not all.
But it would be the particles getting stuck in the check valve that would make it not close and leak back if the spring still has the same load rating.
I would be interested in back flushing it and also disassembling one.
maverickagm
New Westminster
I have a gen 1 that also has a long crank. I know my fuel tank has been out before, but I'm not exactly sure why.
I never liked the idea of dragging out the tank to replace the regulator, only to have the problem come back. Interesting note about particles in the check valve. I'm curious if adding an external check valve after the filter would help, and last.
I have some an6 hose and fittings. I ordered a Radium check valve and some 5/16 efi quick-connect to an6 adapters. They won't be here for a few weeks though. My plan is to have the filter male end adapted to an6, loop around with the inline check valve, adapt an6 to a male 5/16 quick-connect. Then the stock hose that usually goes into the filter will go into the new hose. This way if it doesn't work, it's easily reversed. I'm not sure how much of an impact it will have having the check valve aprox 30 inches from the regulator. Hopefully it doesn't look like a caterpillar of adapters....
I've heard the suggestion of adding an inline regulator before, but I've never heard anyone mention what actually worked for them, what parts they used, and where/how they mounted it.
That sounds like a very logical course of action. Here is what a typical check valve in the pump discharge nip ple looks like. The pump on the right has it, the left one does not. I guess it's possible for the thing to come apart, get into the regulator and lodge the bypass window partially open. That would lead to both low pressure and multiple key-on cycles to get enough to start. Also attached is the patent diagram for this style of regulator.
@maverickagm no effect. the check valve can be 30 inches or 30 feet from the regulator.
Adding an inline regulator is not a good idea unless it has a fuel return line port. The back pressure on the pump will kill the pump.
maverickagm
New Westminster
No no, not an inline regulator. That would be a bad idea. Just a simple one-way check valve to help keep the line pressurised (or at least keep fuel in the line) once the ignition is turned off.
In the youtube video you posted above, the guy does the same, but puts his check valve above the gas tank, immediately after the regulator.
ninetyfive
ninetyfive
Chicago
@maverickagm what do you think about the check valve causing rail overpressure, leading to leaking injectors. Don't we need a way to relieve increasing pressure?
Unless the regulator fails and the pump can pump upto 90-100psi, nothing really to worry about. But check whatever injectors you have max pressure spec. Some bosch top out at 75psi
That's why I said not to waste time with a check valve or that stupid timer someone was selling and/or showing people to wire in. Just cycle key to build pressure is the cheapest work around until you can fix it.
Or just wire in a push button switch to the fuel relay to run the pump.
maverickagm
New Westminster
So I installed my check valve after the fuel filter. After a few weeks, there's no leaks and it does work. I've left the car sit for a day, 3 days, and a week. It starts just as fast as any other normal car.
Fortunately it's not too bad to check for leaks. Using a camera phone I just record a video at 2x zoom with the light on. Lay on the ground, extend you arm between the exhaust tip and rear tire. Aim for the pinion yoke then point the camera up to find the fuel filter and check valve.
Nothing rattles or hits from vibration. Everything is secure as long as the fuel filter bolt is good and not stripped. The only downside is how awkward it looks.
Check Valve:
Radium Engineering Universal Check Valve Kit 6AN (20-0534-06)
Fittings (I bought Evil Energy fittings):
2x 180 degree fittings. Hose-end to 6AN female
1x 6AN Male to 5/16" Quick-Disconnect Female
1x 6AN Male to 5/16" Quick-Disconnect Male
1x aprox 12cm length of 3/8 steel braided hose
Let me try to recall this caterpillar....
The check valve comes with several adapters. Configure it to have AN6 Female on the inlet, and AN6 Male on the outlet.
Fuel Filter > 5/16" Quick-Disconnect Female to Male AN6 > Check Valve > 180 degree Female AN6 to hose-end > 3/8" hose > 180 degree hose-end to AN6 Female > 6AN Male to 5/16" Quick-Disconnect Male > OEM Hose that would normally go into the fuel filter
For the length of hose, I measured 6.1cm of hose excluding any metal fittings. So that size would likely change depending on your fittings. I had to dry-fit everything without the hose then measure exactly what I needed.
I attempted a straight path off of the fuel filter but there was no way that was fitting so I had to make a loop.
Pics below:
SteveGT21
